unconfigure radius
unconfigure radius {mgmt-access | netlogin} {server [primary | secondary]}
Description
Unconfigures the RADIUS client configuration.
Syntax Description
mgmt-access Specifies the switch management RADIUS authentication server.
netlogin Specifies the network login RADIUS authentication server.
primary Unconfigures the primary RADIUS server.
secondary Unconfigures the secondary RADIUS server.
Default
Unconfigures both primary and secondary servers for management and network login.
Usage Guidelines
If you do not specify any keywords, this command unconfigures both the primary and secondary servers for management and network login.
The following list describes the available keywords:
  • mgmt-access—Use this keyword to unconfigure only the server(s) for management functions.
  • netlogin—Use this keyword to unconfigure only the server(s) for network login.
  • primary—Use this keyword to specify only the primary RADIUS sever.
  • secondary—Use this keyword to specify only the secondary RADIUS server.
The following command unconfigures the secondary RADIUS server settings for both management and network login:
unconfigure radius server secondary
The following command unconfigures the secondary RADIUS server settings for only network login:
unconfigure radius netlogin server secondary
The following command unconfigures all RADIUS server settings for only management functions:
unconfigure radius mgmt-access
The mgmt-access and netlogin keywords were added in ExtremeXOS 11.2.
Platform Availability
